first steam boiler of the season
Paul S_3
Member Posts: 1,295
haven't posted in sometime, been busy with refrigeration and ac....3 inch drop header Williamson GSA100, VXT feeder, Vaporstat with 0 -3 psi gauge, we used 2 Gorton #2's. i was planning on using big mouths but currently out of stock.
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
2
Beautiful install as always @Paul S-1
Well done @Paul S ! Fine looking work.New England SteamWorks
newenglandsteamworks.com-1 -
Agreed. They will love the way that system works.All Steamed Up, Inc.
Consulting-1 -
Ya might wanna take that handle off of the manual fill valve. I just left a job where some knucklehead "plumber"/handyman had turned off the main water valve, then decided that the boiler needed filling to 10 psi and flooded the entire system. Water was spraying out rad vents everywhere on the first floor.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1
- 50 Industry Classes
