Temp required to fix kinks in Wirsbo hePEX?
Steamback
Member Posts: 39
I know I can use a heat gun to fix kinks in Wirsbo hePEX, but it has me wondering what temperature is required (minimum) before the product starts to return to the original shape? Is that temperature higher than the published max temp ratings or possibly close to or a little lower than the published max temp ratings?
The guy I was working with today installing Wirsbo hePEX kinked it bad. I told him to flag it and we'd come back later to fix it. However, that didn't happen and the kink is now buried under sheet plates somewhere.
It just got me thinking, maybe running the radiant system at a high temp close to the max temps for the tubing might actually take some of the kink out naturally? Or is that just dumb thinking and high hopes?
After coming home and having a beer I realized I could have just used my lighter to fix the kink right then and there. Or so experimentation is showing me, anyway. Live and learn...
256*F . The tubing will become clear just like when it rolls out of the extruderYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Open flame is not recommended. If nothing else you can try to use a pair of pliers and squeeze it back into shape.0
If you could squeeze it with pliers , don't . Heat it using a heat gun several inches from the tubing . Keep the heat gun moving a few inches either side of your defect and try to heat as evenly as possible . This is the only proper way to repair the tubing . point being that if you can attempt it the wrong way you can use the right methodYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
- 52 Job Opportunities
- 19 Recall Announcements
