Another steamer replacement
Installed a Crown BSI 172, 3" drop header and 2 stage firing set up.
Upgraded the main venting with 4- Barnes & Jones big mouth vents.
nice & neat in a tight spot0
Beautiful!
Love how the gas line is tucked away in the corner.
Is there room on the 1/2" for a valve and union?
I'm not a pipe fitter, but that sure is a purty job. I hope you had aluminum wrenches for the 3".0 -
The valve and union are upstream on the 3/4" @HVACNUT0
The gas line is 1" and there's a 1"x 1/2" tee for the boiler.0
> OK. I thought code was to have a union on the horizontal, so piping doesn't need to be removed to replace the gas valve or pull the train.0 -
I find code discussions here, not very useful as every area has its own set of codes, and laws....I do find that NFPA 54 pretty much sets the standard, then A H J chimes in with there own little pet peeves...some good some not so good....Code comments cause a lot of wasted time. Jmo0 -
Whoops failed to mention, what a nice job...so much work goes into jobs like that. The logistics alone are difficult.let alone the selling,sizing, paperwork, permits,standing inspection, hoping on start up some factory worker did not have a bad day on assembly, humping the old one out and getting rid of it, fearing the call for no heat from a pissed of customer only to find out he failed to replace his t stat batteries, oh and the schooling and time as a apprentice just learning how it all works together...That's not a rant but just a reminder how difficult it is to get to a point that you can preform a complete job like that...1
Nice job @EzzyT !
@j a
Forgot to mention that on top of all that, he comes here and spends time helping others!
Reminds me of a joke our violin professor used to tell us when a patron asked if they (pro musicians) got together on the weekend to play chamber music just for fun. They are so good, and it's so enjoyable, they just must be! He answered "did you ever hear of butchers getting together on the weekend and butcher for fun?"
At any rate - you all go above and beyond despite it all!0 -
@ja
Not being an installer, I look through the eye (yes eye. I'm a cyclops) of a service tech. Having to replace that gas valve would be fun. If I had to replace it, I would bring 1/2" nips and a union with me. Not a biggie I guess.
It is a beautiful installation nonetheless.0 -
Nice job @EzzyT !
@j a
My recent YouTube viewings have been flashmob operas. I love opera, I would truly die a happy man if I found myself in the middle of a spontaneous (to me!!) opera at the grocery store. I'm thankful people who are talented and willing to share their talents in spontaneous acts of culture.
Sorry for the off topicPeter Owens
SteamIQ1 -
@Sailah
Really off-topic:
You need to check out various college summer programs in Italy. There are a few with many open door performances by some very talented kids, all free of charge, or quite inexpensive.
Lucca comes to mind. (http://www.vocalacademyofitaly.org/) Birth city of Puccini, and just an amazingly beautiful city nestled in the heart of Tuscany. If you have 15 min, check out the video that's on the site.
It would make for a great excuse to travel AND get some great singing in. Also, Verona is close by, and their summer opera in the old roman amphitheater is to die for.
Ok. Done. Back to hydronics...
-1 -
Wagner, Ride of the Valkyries. Doesn't get much better than that. BTW, good music to have on when tackling new challenging piping issue!HVACNUT said:My favorite opera is Bugs and Elmer in 'Kill the Wabbit'.
https://youtu.be/xeRwBiu4wfQ.
Been plumbing since the 80's never heard of unions needed to make the gas valve removal 'easy', they're just needed to make it possible.j a said:> @HVACNUT said:
ET, looks superb, what do the ball valves do?1 -
Thanks @GW . The king and return valves are use during annual maintenance. Shut them all off fire boiler until measure reaches about 5-7 psi and then open the boiler drain and the pressure will flush out all the mud out of the bottom of the boiler.1
Can I ask how the two stage gas valve works, I think I could benefit with my BSI 138 at home. Thanks !Gene in Northern NJ
NJ HVACR License 19HC005376000 -
The vaporstat is what triggers the low fire on the gas valve. Once the system reaches a certain pressure then it goes into low fire and stays in low fire until the thermostat is satisfied0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
