PVC Venting / Power Vent Water Heater
Bug512
Member Posts: 52
Hello, checking out the ASTM standards for venting a power vent water heater. I would like to use long radius 90 deg elbows. Problem is I can only find Schedule DWV or ASTM D 1784. This is non pressure application. The temperature range is 140, same as a Schedule 40. Manufactures call for ASTM D 1785. I can not find a fitting that meets that. If I look at Muller Industries their DWV fitting meet ASTM-D2665. Any one ever run into this ? Thanks!
Gene
Gene
Gene in Northern NJ
NJ HVACR License 19HC00537600
I could of course be wrong but my understanding is that "IPEX" is the only brand of PVC that is "listed & approved" for venting. Don't know if they have approved long radius 90s0
When I feel the need for less restrictive flow I use 2 45 ells with some length between. Even a street 45 glued directly into a standard 45 will give you more radius.
I used to do the same thing for DWV to avoid sharp turns especially on the horizontal run.0 -
Thanks for the info. The two 45's make a lot of sense.Gene in Northern NJ
NJ HVACR License 19HC005376000
- 116 Geothermal
- 169 Indoor-Air Quality
