Help Identify Valve
Dan Foley
Member Posts: 1,268
I looked at a vapor system in DC today. There were several Hoffman graduated inlet valves. There were also several of these which I could not identify. Any help is greatly appreciated.
I also saw this double check on the return. I have worked on a lot of steam boilers but I have never seen a double check on the return like this.0
If one check valve isn't enough, use 2!!!
I guess the installer must have lost a boiler once from a broken return line!!0 -
Those might be Hutchison valves, which would make sense because that company was located in DC. Have to clean them off so we can see the trademark to be sure.All Steamed Up, Inc.
Consulting0 -
I have worked on many Hutchison systems. These are not Hutchison valves.
I was just there on a visual survey so I did not want to do a lot of scraping. If I end up going back, I will sand the valve body and get a better picture.0 -
Dan, I didn't have any luck tracking down that valve online, but I noticed something similar on the Radiator Renovator site (https://radiatorrenovator.co.uk/radiator-valves-accessories/). They were unable to identify your valve, but they do have a modern valve based on that style. Please keep us posted on the mystery valve!
President
HeatingHelp.com1 -
Thanks, Erin. Those valves are similar.
I will get more info when I go back.0 -
Hi Dan, just wondering if you had any luck in tracking down your valve?
Andrew0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
