Viessmann Trimatik BEA-29, contol panel, 1990 model
My timer no longer works, and looking for a complete control panel replacement. I'll assume the circuit boards behind the time are no good. This Viessmann was built/installed in 1990, and performed flawlessly since. Any recs would be greatly appreciated. I did contact Viessmann Co. and they do not have inventory for this old model.
  • GW
    GW Member Posts: 5,133
    what did they say?? Did they say what you needed??
    I once replaced a Trimatic controller once with a modern version of the same control. It wasn't super fast, just takes time.
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • GW
    I read too fast, you have a Trimatic control on a BEA boiler? You may be booking at a Vitotronic 200
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • edmund
    edmund Member Posts: 2
    Appreciate the reply Gary. However, luck came my way. I removed the clock and cleaned the terminals - even though they appeared clean - reinserted clock into control panel, and it's working again!!!
    I hope it holds for another 26 years because the upgrade panel is too much for my simple house/lifestyle. This Viessmann may be like my old Farmall flathead tractor, you just can't kill it.
  • GW
    ahh nice to have a good story every once in a white, good for you!
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
