Warmboard
Susan_R
Member Posts: 1
Typically a cement backer board goes over the WB for tile installation. The Hardi brand is either .025 or .040 thickness. how thick is the tile?
The wood supplier should have transition pieces to match the flooring to transition between the two materials if they are not exactly the same.Bob "hot rod" Rohr
Living the hydronic dream1 -
