Cast iron baseboard question
rickster05
Member Posts: 39
Just picked up 19 ft of Crane baseboard. One unit is 13 ft and one is 6 ft. They will be in series one next to the other. If I connect the two on the top ports where I am continuing the series, can I just vent the top end of the second unit? My grandfather was a plumber and I learned a lot from hom regarding plumbing, but this is the first time I have repurposed cast iron baseboards. I'm assuming that since I am using the top port to connect I can just add a bleader on the top of the last register. Thanks all!
Tarm Solo Plus wood boiler with 600 gal storage tank using repurposed cast iron radiators.
Here's this instructions for venting on Burnham BaseRay/Gov-Board cast iron baseboard...
Venting-
When two or more Gov-Board assemblies are connected in series on a hot water job it is necessary to vent each assembly, unless the assemblies are connected at the top tapping.
When connected in series on a two-pipe steam job, the assemblies should be connected at the bottom, and only one steam air vent need be used.1 -
Thanks guys! I should have mentioned it was forced hot water.Tarm Solo Plus wood boiler with 600 gal storage tank using repurposed cast iron radiators.0
Looks like the top port connection then with a single vent in the top port of the second register.Tarm Solo Plus wood boiler with 600 gal storage tank using repurposed cast iron radiators.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
