Putting Together a Hydronic course
eddiecalder
Member Posts: 4
So I'm in the process of putting together a Hydronic course for the school I work at. I'm a full time Refrigeration instructor that holds a Red Seal in Refrigeration and Plumbing. I have my Gas B ticket and an Cross-Connection certified (may have actually lapsed).
The course I'm trying to make is for Hydronics and not for boilers specifically. Chillers, cooling towers, heat reclaim, building loops, condensers will all be discussed in the class. It is meant to be an introduction to using fluids as a medium to move heat.
Is there any reference for the cooling side of hydronics that I should reference?
The basic topics I'm considering at this time are:
Basic Theory:
Introduction to heat and matter (specific heat formula, sensible heat formula, gas laws)
Major components
Near and Far piping (direct return, reverse return, injection, close spaced tees, etc)
Mixing valves
Pumps (curves, pumping away, injection systems etc)
Accessories
Heat Pump Loops
Heat recovery options
Fluid Coolers, Condensers, Cooling Towers, Evaporative Condensers,
Safeties and Control systems (intro to DDC) (Tekmar has been requested specifically)
Balancing
Backflow devices
Water treatment
Design and installation practices
Basic service procedures
Practicals:
System Design (pump sizing, pipe sizing, Heat load calculations, )
Taking apart and servicing pumps
Boiler teardown and maintenance
Cooling tower cleaning maintenance
Wiring project (simple control circuit with pump and zone valves)
Anything I'm missing here that you would think would be of value for an introduction?
I have complete freedom with the course length and time allocated. I'm hoping to keep it under 24hrs total split between nights and weekends.
Basic Theory:
Major components
Mixing valves
Accessories
Heat Pump Loops
Balancing
Backflow devices
Water treatment
Practicals:
We have supplied Idronics to many different training facilities over the years. Here is a link to look over the offering on the various topics.
Issue 12 Hydronic Fundamentals is a good issue for newbies.
https://www.caleffi.com/usa/en-us/technical-magazine
If you want a full on textbook look at John Siegenthalers
Modern Hydronic Heating
Heating with Renewables
I think they, and other great reads, are available at the Bookstore here at Heating HelpBob "hot rod" Rohr
Living the hydronic dream2 -
The Caleffi stuff is always good and I also like how simple Pumping Away is, but is there any material specifically for the commercial cooling side of hydronics that you can think of?0
Another great option.
Living the hydronic dream1 -
That and Modern are the book we use in our Refrigeration apprenticeship classes.hot rod said:Another great option.
- 120 Geothermal
