HydroSmart boiler
larryjbjr
Member Posts: 69
in Gas Heating
Looking at this boiler at Menards. Anybody know anything about it?
https://www.menards.com/main/plumbing/rough-plumbing/hydronic-radiant-heat/radiant-heat-boilers/hydro-smart-trade-hs120con-microboiler-lp/p-1444433728524-c-8519.htm?tid=6493386586953731736&ipos=4
Just checking the specs.
93% max efficiency
140* max supply temp, the boiler is for radiant applications and needs their radiant "integrator" panel.
Copper HE
2 year warranty.
I'll take a pass.0 -
What About this one? Seems to be better specs, but I'm not sure about that 3/4" supply and return.
https://www.menards.com/main/plumbing/rough-plumbing/hydronic-radiant-heat/radiant-heat-boilers/westinghouse-premium-dual-purpose-140k-btu-condensing-lp-boiler/p-1444433603451-c-8519.htm?tid=6493386586953731736&ipos=10 -
Or should I just stay away from the big box store boilers altogether?0
JMHO but anything the big box stores is generally the cheapest equipment available. Not the best0
...and then there's the "who is going to service it when it breaks down" question.0
That's a HTP Products UFT boiler simply re-badged under the GE brand name.larryjbjr said:What About this one? Seems to be better specs, but I'm not sure about that 3/4" supply and return.
http://www.htproducts.com/EFT_Combination_Wall.html
The 3/4" supply & return is for Domestic Hot Water, the space heating connections are 1".
You can purchase HTP boilers at plumbing supply houses where you can also find parts for them and warranty service and installers.
The HTP UFT boilers come with a 10-year Heat Exchanger warranty...0
- 123 Chimneys & Flues
