leak seal kits
Are leak seal kits good to use? I have heard mixed results.I have a Goodman HVAC system installed in 2009 with a small leak, maybe from the evaporator coil.I have heard of that brand from that year having problems with leaks at the evaporator coil and bad fan motors. I was wondering if it is better to replace the coil if that is where the leak is or just add the leak seal to the system.
  • ChrisJ
    ChrisJ Member Posts: 16,853
    edited July 2017
    Isn't that still under warranty?
    Of course new is better than leak seal. Personally I'd never use leak seal, but, some guys swear by it.
    If I had to give advice, I'd say the only time to ever use leak seal is on a dying system that you're trying to limp along another year or two. Never on something you, or the customer actually care about.
  • newagedawn
    newagedawn Member Posts: 586
    i agree, if its under warranty get a new one, i deal with Goodman all the time and my supplier would replace it in a heart beat, but then you need to pay someone to change it, unless you got the insurance for a ten yr warranty that covers parts and labor
    and
    is that the reAL question cheap it or spend the money to fix it?
    i have used leak sealers and for small leaks they work great but for bigger ones not so good, its always a gamble with a leak seal
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
  • chap007
    chap007 Member Posts: 20
    Thank you Chrisj and newagedawn,
    The unit is only 8 years old and I intend to get many more years, so we will fix it instead of sealing it.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,241
    Small hard to find leaks , leak seal is an blessing ..
  • unclejohn
    unclejohn Member Posts: 1,833
    Goodman uses a crimp seal on the process tube on many of their evap coils. It's a simple repair and easy to find with soap.
  • ChrisJ
    Isn't a process tube when they crimp off a line after vacuuming and charging small appliances such as a dehumidifier or refrigerator?
    HVACNUT Member Posts: 6,872
    >> I think he's saying that's a prime location for a leak to be found on a Goodman evap.
  • ChrisJ
    edited August 2017
    Yeah I saw that.
    But what is he calling a process tube in this case? I don't think Goodman makes anything with what I think a process tube is. Or do they?
