Help. what's leaking?
aherring
Member Posts: 4
in Oil Heating
We went away for vacation and came home to a slight oil smell in basement. We found a leak near the hot water heater. Our house is on the market and we were wondering if someone messed with something while looking at the house or if this is a new problem? There's a valve near the leak? Should it be open or closed? Thanks for any direction or help! Or an idea of what the problem is and what we might be looking at for repairs (major, minor, etc). Pictures uploaded for reference!
Thank you. It's the 4th, so ... Is this an emergency or can I call someone tomorrow? The oil smell makes me nervous!0
I would guess you could wait until tomorrow. That small valve may shut off the supply or there may be a valve at the tank.
Even with the oil off it will continue to drip quite a while.
Put a pip pan under the drip to prevent more floor staining.
If you soak any up with a rag be sure to put the rag outside your house to dry up.....not in a closed can.
I have seen much larger oil slicks in household car garages.-1 -
Yup. Instead of soaking it up with a rag, though, try cat litter first (as a cheap alternative -- an auto parts store may have speedidri, which is more expensive but works better).Br. Jamie, osb
It's either the canister or the gasket. A small leak at the gasket will run down the side of the canister and form a drip like that. Or the bottom of the canister could have a pinhole in it.
Either way, call your oil guy.All Steamed Up, Inc.
Consulting1 -
Hi! Itwas the filter canister. We had it serviced at the same time as well. It was overdue. Thanks for all the help!0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
