Smith RTS28HE boilers
Mike
Member Posts: 94
Anyone have any experience, with these boilers? Namely the return water temperature staplyizer? A 4inch SS capped tube in the section, with 1inch holes directing flow down though each section. I'm wondering about enough flow through the boiler?
garbage boiler"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
The 28s have been made since the late 1970s. There's a ton of them in the field.The return temperature stabalizers are fairly new I think
You size the pump right flow will not be an issue. Good boiler0
