Rinnai R53 Water Heater Leaking
bmp68
Member Posts: 1
I have a Rinnai R53 Tankless Water Heater that's 11 years old. It has developed a leak, but it still heats just fine after all of these years. The leak, as best I can tell, is coming from the air inlet assembly, (or somewhere there about). I'm thinking it has something to do with the condensation, but I'm not for sure as I have very little knowledge about these water heaters. Can someone advise on this? I've attached a couple of pictures that I'm hoping will help.
Check the pitch of the exhaust....Recently serviced?...0
While firing, do you see green on the heat exchanger? That and water in the fan assembly is a sign of a cracked HE. If that's the case and you decide to change it, take pics and seperate and label the screws. I use the cardboard from the box and insert the screws like push pins. Been a while since I replaced one but there's something like 87 screws.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
