uponor 4 zone control module
pooteo
Member Posts: 19
I have a taco 4 zone switching relay with 3 zones already hooked into this for radiator heating. i recently added a 4th pump to the system to use for the radiant floor heat. I bought the uponor four-zone control module and hooked up the thermostats and the actuators. they all work fine. can i connect the uponor four zone control module to where the 4th thermostat would connect too on the taco switching relay to control the boiler and pump.
In other words. The instructions say to connect the ES sides on the control module to the boiler and pump, but i want to connect them to the 4th relay on the taco where the two thermostat wires would be connected.
You most certainly can .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330
- 52 Job Opportunities
- 19 Recall Announcements
