Interesting Radiator Plumbing!
Harry_6
Member Posts: 147
I came across this youtube of a gentleman installing radiators in his house. A cookie to anyone who can spot the problem(s)! www.youtube.com/watch?v=OIDZFkUxFTU
I think you have a bad link there.0
I think you're right. For some odd reason I can't link to the url. Even the copy and paste version won't work?! Well, if you're interested, the youtube is called "cast iron radiator plumbing" by "Stoker Don." You can go to it via the title, but for some reason I can't copy the url and get it to work. It won't even let me link to the saved version on my computer. God, I hate these things.0
Looks like a low temp supply would work......so is that a ModCon coal burner??0
That is a massive amount of radiation for one small room. I read comments and he claims to have run heat loss, I think he carried too many 1's.0
Expansion...contraction? No worries about oxygen?
The basement-I nearly threw up in my mouth.There was an error rendering this rich post.
Well, my first thought was also that it was WAY too much radiation (although it IS hot water), but he has daisy-chained together a row of radiators with one small pipe at the bottom. Well, that's not great practice flow-wise, since the water only has incentive to flow directly from the inlet to the outlet, without much circulation taking place (although they did sometimes do it in the old days - but with bigger pipe). But also, they're in series. So the water temperature, even if he had used large enough pipe, would still be very low by the time it exited. That's one reason they usually took them off the mains individually. So my thought was: too small pipe, dubious flow and too much radiation in series. If it was me, I'd have bitten the bullet and piped them in individually - ideally top and bottom (although some of his can't be set up that way).
I would also have used steam instead.
I get the feeling he figured out a heatloss (not necsarilly for that room), figured out how many feet of baseboard he needed to satisfy it, then put that many 'feet' of radiators in.0
I'm with @STEVEusaPA .......the basement
That's why the movies always tell you: "Don't look in the basement!"0
https://youtu.be/OlDZFkUxFTU
