Burnham Freedom
happydave
Member Posts: 79
Customer called hot water, Freedom120. B25 error code. Temperature risen to quickly, call Burnham, they ask about system (we didn't install) talk pump sizes, indirect had 007 had to be 0014 so I replaced. Purged whole system with hose to mop sink a good 10 minutes. System error coding again, wondering if I have a particularly open/stuck check valve? Installer used a swing check, I would have used a spring or weighted check. System doesn't error out when running for heat. Ideas? Thanks
Got a piping picture?0
Burnham believes it's the high limit sensor, the problem is the part number they have is not the right sensor. My sensor is different, must be the first series boiler. I've got spade terminals, the new one is plug in. I really don't want to cut the harness to find out it really isn't the sensor, ugh0
Just curious if you solved this problem? I happen to have the same boiler, and would like to know what the solution was.
Thanks, J0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
