Solder a Caleffi Zone Valve with the Valve Open or Closed?
Either way is fine, remove the actuator when soldering.
Lead free brass heats differently, heat the tube and body evenly to get a good joint.
Lead free fittings tend to expand more than leaded and heat doesn't transfer to the tube as well. This can cause you to overheat the brass and burn it.Bob "hot rod" Rohr
Thanks Hot Rod!0
- 120 Geothermal
