Are there effective electric heaters for a 400 sq. ft. uninsulated rock wall room?
13»
    EBEBRATT-Ed Member Posts: 19,427
    Electric baseboard will work fine if you put enough in, but you won't like the bill. Otherwise it's steam or hot water radiation.
    forget any ductless split or ducted system it will never work.........unless you stud the interior walls and insulate and add insulation to the ceiling as well. then you can heat it with whatever you wan't
  • KC_Jones
    KC_Jones Member Posts: 5,903
    Glad to hear it's going well!
    2014 Weil Mclain EG-40
