Can I add Myson radiators to an existing Cast Iron system?
cma0651
Member Posts: 1
in Gas Heating
I am rehabbing a home and the bank did not winterized the house properly, about 1/2 of the cast iron radiators have cracked tubes.
The supply lines looks good, so my question is, can I swap out the cracked radiators with a modern style, like a Myson? The supply line is 1" and Myson and others requires 3/4" and the radiators run in series.
I assume this will restrict the flow to the older radiators, but will it have a noticeable effect ?
Thanks in advanced!
Thanks in advanced!
Water takes the path of least resistance. The will be little or no flow through the new rads unless they're piped and pumped as a separate zone.
Here's a current thread discussing it:
http://forum.heatinghelp.com/discussion/161590/no-flow-in-a-baseboard-heater-recently-upgraded-from-a-radiator#latestBob Boan
Where are you located at.
I would replace them with cast iron radiators.
