Steam pipe in attic
SeanBeans
Member Posts: 520
This steam pipe is going up into the attic.. but there is no access to attic and guy wasn't into poking holes to find out.
There is a steam vent here as seen in the picture below.. it looks like the only steam vent on the whole system beside the rad vents of course..
Down feed system.
You may have something like this:
Bob Boan
Is this an operable system currently? If not you may have to get there and see what's going on. Could have been a riser left for possibly heating "attic" at some point. There actually might even be a rad there for all you know. This will have an effect on sizing a proper boiler.0
The rest of pic is dark, an not being able to see what room this is, possibly a bathroom given that stack in the chase, pipe may have been used like that with a vent as a heating surface, i.e. radiator and is capped above the ceiling0
Looks like 1-1/4 pipe, no? Too small for express riser, I'd suppose, but who knows. Max EDR 1-1/4 pipe carries is not that large...0
All rads were fed by 1 1/4 pipe0
Was a bathroom under renovation.,
The water meter and gas are shut off to the house.
I was thinking that it was just capped off at the top. There is a parallel flow main and a counter flow main with no return in sight.. the parallel main is about 30 feet of 1 1/2 with 4 of 5 rads in the house and no vent on it. Not even plugged anywhere
Cointerflow main will have a drip somewhere at the start of the main, or at least it should. By the book, mains should be 2" minimum. 1-1/2 main will not safely cary more than 152 EDR in parallel flow pipe, and only 81 EDR when counterflow. What's the total edr load per main?0
Are there radiators that you can't trace where there being supplied from? Is there any indication that the pipe going to the attic is serving another radiator? If not, your probably right in thinking its just caped and the pipe is just the radiator for the bath room.
in my opinion, need access to the attic, cut a 2'by2' hole in a convenient room and make an access panel and put the mystery to rest,...lol"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
I agree with above, the pipe is likely "the" radiator for the bathroom. Leave it alone and just swap the vent, unless you want to re-fit the piping and install a conventional small cast iron radiator.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
