how did that work ?, steam is amazing
newagedawn
Member Posts: 586
dont know how this worked, but i know this will work!!!!
"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
1
Looks good! Do you do a lot of steam?All Steamed Up, Inc.
Consulting1 -
been servicing steam for yrs but never installed one, that was my first !!! and im very happy with the way it turned out, thanks to dan holohan for his books and the input from this site , very thankful ,
this job used to bang, clank and spit, but NOW cant even here a mouse,..lol , i want more,..lol"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"2 -
First thing to do is get on the Find a Contractor page, if you're not there already. Get in touch with @Erin Holohan Haskell to find out how.All Steamed Up, Inc.
Consulting-2 -
Bio said:
Is the LWCO in the wrong spot?
Actually, according to the tapping diagram:Fred said:Yea, The LWCO is way too high. It should be in that tapping down low, under the Presssuretrol/pressure gauge. It is to shut the boiler off at a low water level. Where it is now it will shut the boiler off every time it runs and then flood the boiler with added water.
http://www.peerlessboilers.com/DesktopModules/Bring2mind/DMX/Download.aspx?EntryId=37&PortalId=0&DownloadMethod=attachment
that tapping location is correct for a primary LWCO. I'll bet the LWCO is mounted so the probe attaches at the bottom of the housing, which makes it look too high in the pics. This would also put the LED indicator lights where you can't see them.
The other tapping is for a secondary LWCO.
Not sure what (if any) Codes are in force in that area regarding the oil tank location relative to the boiler.All Steamed Up, Inc.
Consulting-1 -
the low water cut off is in the right spot, i checked the operation, peerless gives an extra spot for extra protection if wanted and yes the oil tank is to close to the burner code is 5 feet but i wasnt contracted to move the tank,we will see what the inspector says and if he catches it im sure i will get contracted to move the tank,love peerless steamers they are the only boiler that has 14 gallons of water all the rest have 10.7, i checked believe me, i like the fact that peerless offers a larger water content than all the rest for steam i feel its needed , thanks for the observations guys!!!, but this job is solid, i guarantee it, its my reputation and here in CT i have a solid built reputation for fixing problems no else can and installs that are the best around this area, thats how i got this job!!!"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
Worth repeating.Steamhead said:First thing to do is get on the Find a Contractor page, if you're not there already. Get in touch with @Erin Holohan Haskell to find out how.
Consulting0 -
@newagedawn - Here's where you can sign up for Find a Contractor: https://heatinghelp.com/find-a-contractor/get-listed/
President
HeatingHelp.com0 -
If you do have a problem, instead of moving it, you can construct a 1 hour fire rated wall between the two.newagedawn said:yes the oil tank is to close to the burner code is 5 feet but i wasnt contracted to move the tank,we will see what the inspector says and if he catches it im sure i will get contracted to move the tank
My apologies @newagedawn . The LWCO looked way to high. Obviously not!0
Do you have any pictures of the back of your boiler where the equalizer and Hartford loop connect?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
@Alan (California Radiant) Forbes its just the 2 " equalizer into a 2 by 1 1/2 tee it reduces to the boiler to 1 1/2 and the returns go to the 1 1/2 hartford loop,... i think i have a pic if you really want to see it"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
Code says 5' to the tank from source of ignition. That is NFPA code nation wide. The rest looks great.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
