Recommended circulator pump
Bry_2
Member Posts: 14
I am installing a used Weil Mclain boiler to run a new hydronic system but it has no circulator pump on it. What type of pump would be best for a 1 storey, small bungalow running 8 rads off a 3 zone system? Thanks.
A little more info would help. Is this a cast iron boiler?
What size and how long are the piping runs?
Albert Einstein0 -
Radiators normally are piped on an diverter type system or home run ..8x3 assume an diverter . Which would be low head higher volume .. With three zones and one pump ? I would favor a variable circulator , I would also use on an home run ..
Wilo stratos, taco 007e, or grundfos alpha would be my suggestions.0
i like the grundfoss alpha there alittle expensive but work well with raidiant"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
Sorry, I was away for a week. I should have specified. 95K btu cast iron boiler previously on a gravity fed system fed with black pipe. Conversion to pex al pex feed lines off a 3 zone manifold but I need a circulator pump to feed the zones. Will be using zone valve meters to control flow to each zone. Thanks.0
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
