Oil tank gauge
Fizz
Member Posts: 547
in Oil Heating
Recently had boiler serviced, and as part of it they suspected line blockage from tanks. Each tank was checked and worked on. Interesting observation was after they left I noticed the gauge glass showed 3/4 full, whereas before it was just 1/2 full. What do you make of this?
Fizz
Fizz
Gauge was sticking. They probably thought it was a blockage if the two tanks were piped together at the bottom and the gauges read differently. So they unscrewed the glass (plastic) gauge cover and the 1/2 full one probably popped up to the proper level.
Or there was actually a blockage. I guess you didn't ask them.There was an error rendering this rich post.
There's only 1 gauge, and you're right, I didn't. Stupid is as stupid gets.0
That's good news. Thanks.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
