Newly installed
SeanBeans
Member Posts: 525
When you dont know how to get a 3 inch elbow off...
I'll second that. That guy didn't read the manual. He reduced the 2-1/2" steam outlet to 2" with a bushing, which is a big no-no on a Dunkirk boiler.Fred said:I would say "When you don't know how to properly install a steam boiler".
Then there is a concentric reducer on the header before the elbow to the equalizer. This will trap water in the header.
This will produce wet steam, reduced efficiency and possibly banging.All Steamed Up, Inc.
Consulting0 -
A tubing cutter would have eliminated that 3" el in about 2 minutes.Steve Minnich0
- 62 Biomass
