Vapor System Crossover Traps
I doubt that i t would hunt -- there is no condensate available to a crossover trap to cool it off. It might crack open a bit now and then, but would reheat and close almost immediately.Br. Jamie, osb
Would it stay closed longer in that hot spot, creating a vacuum in the system that may be desired?? WAG0
Maybe it doesn't matter which way the steam flows through the crossover trap. The element will still be exposed to the steam, and close.
One consideration would be convenience in checking the trap for leakage, by cracking the union nut, on the discharge side of the trap, and checking for steam coming out.--NBC0 -
Those are all food for thought.0
Fume hood is good vapor system you can try it, it can remove all vapor, moisture, and other biological agents from work place. these equipment used at huge level of work like research work or hospitals some more equipments are used in that works like bacteriological incubator, incubation chamber and etc.-2
Ask and ye shall receiveMilanD said:Perhaps @Sailah could set up one trap like this "backward" on his test station and see how it operates vs. the regular setup. I'd be curious too.
https://youtu.be/XI7uiHaT25U
Peter Owens
SteamIQ3 -
-1 -
Thanks a bunch! And now we know. One less question to keep us awake at night. Perhaps some are just installed wrong!0
Nothing like a real life experiment - thanks!Br. Jamie, osb
I had a couple dorm buildings full of those. They were called "outboard" traps and since the union nut was on the orifice end of the trap, they were designed to be operated that way. The radiator traps were also all that way. My comments; they work fine but it was a b**** to get the cap on without the element falling sideways. I have no idea why they did this, but it was only for a short while in the early 1940s. I had a new building every 4 or 5 years from 1911 through 1960 with vapor systems in them, a veritable museum of vapor systems. The 1911 had a vari-vac in it (no longer complete) with 2 zones of outdoor reset on steam.0 -
Where is this? It would be a prime location for a steamheads tour!Noel said:
It is active residences, so no tour. I'm not there any longer. I took Steamhead through there once.
http://studynh.com/colleges-universities/colby-sawyer-college/1 -
This would purely feed my curiosity... There is reading Mr. Holohan's and other old books, but then there is seeing it in person working...0
That was one of the most interesting building tours I've taken.Noel said:It is active residences, so no tour. I'm not there any longer. I took Steamhead through there once.
What are you up to now, Noel? Been a while...............All Steamed Up, Inc.
Consulting1 -
Very cool video Peter. I have often wondered if it mattered as to the orientation of the crossover. Now i know. Thanks for the video. I'm never to old to learn something newSailah said:
gwgillplumbingandheating.com
There was a thread on here about a year ago with a fully intact vapor system that had outboard traps on the radiators. I forget the maker, but it seems like it was Illinois, but now I can't find the information on it. The system that I recall, whatever it was, when reading the rationale on the traps orientation, it was all about the fact the traps close around 180F. In a conventional setup, the outlet corner of a radiator will never fully heat because of the trap closing early. However, with the outboard installation, it will close when steam hits the element, but as soon as it closes, the steam is separated from the element, the element cools, then reopens. Or... as the video clip shows, the traps closed most of the way, but remained open just a crack with steam leaking through, to keep the trap closed, almost.
Personally, it seems to me that in a crossover situation, the outboard setup would not be desirable. The only thing necessary is letting the air out of the main, as opposed to keeping that last foot of the main as hot as possible.
Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Not much new. Lisa found us a house built in 1710 and we bought it. Ripped out the steam boiler and repiped it the way I want it. Had a fellow wallie plumb us a new bathroom that son Seth remodeled. Seth is living in our other house in Sutton now.Steamhead said:
I ride ATVs with my kids and grandson in my spare time. I have a Polaris RZR.0 -
Cool! One of these days I'll have to get back up that way. Been a long time, and I'd love to show The Lovely Naoko that part of the country..All Steamed Up, Inc.
Consulting0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
