Longwood VII Duel Fuel furnace
dsalv
dsalv Member Posts: 5
Just bought a home with a Longwood VII duel fuel furnace with auto damper control. Wood burning auto damper has been disconnected as the owners weren't using it. Need a manual to try to get it back to normal operation. Is there any information or spare parts out there on this unit ? The company is OOB and I haven't been able to find anything so far that shows the auto damper control.
    Jamie Hall Member Posts: 26,459
    The other thread on these furnaces has a link to the manual.
  • dsalv
    Thanks for the response, but I already have that. It does explain a lot about the furnace but it doesn't have any info on the auto damper control so it must be for another model. I need a manual that shows the wiring diagram for the damper control.
    Somehow I have a feeling that you may be on your own on this one...
  • dsalv
    Nice! I'm beginning to feel the same. Thanks.
  • Grallert
    Grallert Member Posts: 993
    hearth.com this is the place to find information on all things solid fuel
  • dsalv
    Thanks. So far no luck there either.
