Longwood VII Duel Fuel furnace
dsalv
Member Posts: 5
Just bought a home with a Longwood VII duel fuel furnace with auto damper control. Wood burning auto damper has been disconnected as the owners weren't using it. Need a manual to try to get it back to normal operation. Is there any information or spare parts out there on this unit ? The company is OOB and I haven't been able to find anything so far that shows the auto damper control.
The other thread on these furnaces has a link to the manual.Br. Jamie, osb
Thanks for the response, but I already have that. It does explain a lot about the furnace but it doesn't have any info on the auto damper control so it must be for another model. I need a manual that shows the wiring diagram for the damper control.0
Somehow I have a feeling that you may be on your own on this one...Br. Jamie, osb
Nice! I'm beginning to feel the same. Thanks.0
hearth.com this is the place to find information on all things solid fuel
Thanks. So far no luck there either.0
- 120 Geothermal
