Chilled Water Manifolds
Ironman
Member Posts: 7,862
Anyone know of a good source for chilled water manifolds? It's a 3 ton system needing actuators for each zone.
Bob Boan
Have you looked at any of the geo manifolds? They are insulated via an air gap between a double wall.0
Thanks Harvey. That looks like the way I'll go, but I can't find any with actuators. Guess I'll have to add zone valves.Harvey Ramer said:Have you looked at any of the geo manifolds? They are insulated via an air gap between a double wall.
You'd think someone would have an insulation kit or an insulated box so that you could use a standard radiant manifold.
I might attempt building something like that.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 167 Indoor-Air Quality
