steam radiators
HEATON
HEATON Member Posts: 121
best(in your experience) way to clean 100yr old one pipe steam radiators. Thanks for all the help in the pa
  • Steve Minnich
    Steve Minnich Member Posts: 2,876
    I'm in the process of cleaning a 140 year old wrought iron steam radiator and I'm using a pressure washer with 3000 psi. Hard to tell how many coats of paint but it was a lot. Took 4 hours.
    Steve Minnich
  • Fred
    Fred Member Posts: 8,542
    I hope you didn't punch through anywhere @Stephen Minnich
  • ChrisJ
    ChrisJ Member Posts: 17,390
    Depends on what tip he is using, but I highly doubt even a 0 degree red tip would easily "punch through" cast iron.
    If it did, the radiator is garbage anyway.
  • HEATON
    Im talking about cleaning the interior of the old rads in service since 1912 on a 1 pipe steam sys. Another wet head told me if tthey arnt banging dont worry about the crud on the bottom
  • HEATON
    still looking for the source of a tank/reservior for condensate, passive, not with a pump. as shown in the piping recommendation of Williamson GSA boiler. appreciate your reply. john
  • Fred
    If they were disconnected and outside, in the yard, I'd hose them out but I certainly wouldn't move them just for that. Not needed.
    MilanD
  • Steve Minnich
    edited February 2017
    I barely got through the paint, let alone the iron.
    Steve Minnich
    Jamie Hall Member Posts: 27,378
    On the inside? Just hose them out. They don't need cleaning inside. Outside? I like the pressure washer if they are where you can use it. Bead blasting also works. If you are just concerned about appearance and are going to paint them anyway, elbow grease and a wire brush work wonders...
    Canucker
  • Koan
    Koan Member Posts: 450
    we had a re finisher dip ours in a stripping tank
  • SteamCoffee
    SteamCoffee Member Posts: 123
    If your so inclined, electrolysis is nothing short of amazing. I had the setup and experience so the learning curve may be higher if you just starting out. The rads cam out like the just had been cast. So pretty, I almost just clear coated them bare...
  • Koan
    @SteamCoffee - I have heard of electrolysis to remove rust, you are saying that it works well on paint as well?? We have one 30 section rad to still strip, and I am trying to figure out how. I would like to hear how you did this please.
    EBEBRATT-Ed Member Posts: 20,190
    Goggle it, all kind of videos on u tube. I never used it for paint only for rust
  • SteamCoffee
    30 sections is a beast, getting it submerged would be tough. Electrolysis will remove paint and rust. Paint comes off in sheets, truly amazing. Lots of info on the internet. If you can devote the time to it, the is no better way...especially for cast iron. Good luck.
    Koan
  • Koan
    @SteamCoffee so - what I am considering is actually building a tank around the radiator. I estimate it to weigh 875 lbs, alone it is 105EDR, more than 25% of the entire heating load. We had the 10 others dipped , but the re-finisher would not take this one bc it is too heavy. The re-finisher said he feared it would remain at the bottom of his tank. Since I want to spray it to paint to match the others (3 part epoxy) , and spraying epoxy in the living room probably means certain death, I assume I will build a cart for this to get it out of the house. I was then either going to soda blast it or build an electrolysis tank around it to strip it. Any brief info you can share about the process is appreciated, I know the general concept... opposing charges on a solution electrode and the piece itself.
  • SteamCoffee
    I have done car fenders, by building a shallow plywood tank with plastic sheeting around it, anode above. My biggest rad was 5 tube Corto 38 in high. Took 12v and 11 amps DC Battery charger to get the ball rolling. About 20 hours for each one. Used Arm &Hammer washing soda as electrolyte. Lots of venting! They came out spotless. Finding detailed info is easy. Building a tank is challenging. Baby pool? Good luck, sounds like a monster rad...
    Koan
