Soaker system operation for closed loop horizontal heat exchanger
bnjmn
in Geothermal
I have a new residential water to air system that I am installing. 4 ton system. System is sized and installed correctly I just more or less wanted to experiment with this.
This is a 4 pipe system with an average depth of 7ft and 700ft of trench. After installing all the geo pipe I ran a 3/4" pipe over top of the system piping in S pattern holes drilled every 18" or so.
I am going to use a 24 volt Taco Geothermal valve for on off control of water. I'm thinking of using a 7 day programmable WIFI thermostat and set up a schedule for a few hours once a week to water. House has a variable speed well pump and I plan on only using 4 gallons a minute when watering so homeowners won't notice any water use noise or reduced water pressure. With the WIFI stat I can always turn it off remotely without having to visit site, I already will have a few other WIFI stats on the job.
I have never installed or used a soaker hose, anyone out there have any control tricks or things they have learned that has worked well?
Thanks, Ben
Thanks, Ben
Will the soaker hose be the full length of the buried tubing-700 ft?
That is a long run to make the holes supply an even discharge along its length. Have a look at some drip irrigation "Rainbird dripline", with emitters every foot, which will be more even, although may still be restricted in length to half that length, depending on your water pressure. The Rainbird website will have tables for determining pressure versus length.--NBC0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
