TM9x080b12mp11a Luxaire /York condensate issues
DZoro
Member Posts: 1,048
in Gas Heating
Had a new customer call today with a York/ Luxaire LX series furnace. This is not our install, a local guy installed a few and then went out of business. So I get the after hours call..... It is the newer series with the clear condensate box. Condensate had gotten into the pressure tube. I cleared all the condensate out, drains pan, removed inducer, checked for proper venter re-stricter. They used 1/2" pvc short drain all appear installed ok. My question is has anyone had issues with these units. I knew I didn't find the smoking gun, and was correct have a second call back. Any info would be appreciated. Forgot also lifted pressure tube up so condensate doesn't gather in it, and bent turbulators straight down behind the venter.
Denny
Denny
- 123 Chimneys & Flues
