Burnham Alpine Header Sensor
PeterWhite
PeterWhite Member Posts: 2
I was wondering whether someone could tell me what the Header Sensor is used for. I noticed that my Boiler doesn't have one installed per the sensor status on the display. Is this of concern? I've searched high and low for the answer, and can't find anything. Thanks in advance.
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    I believe the header sensor is for multiple boiler applications and lead/Lag . If you have a single boiler application it is not needed.
  • rbeck
    rbeck Member Posts: 56
    As usual Tim you are absolutely correct, multiple boilers.
  • PeterWhite
    Thanks for the info. Much appreciated...
