Insulated Near Boiler Piping - Copper
I recently purchased a 1920 era house in the Hampden neighborhood in Baltimore. After reading the forum in depth as well as Dan Holihan's "We Got Steam Heat", I insulated all of the near boiler piping and the mains. My concern is that all of the near boiler piping is copper and now that I've insulated, I believe I'm getting a better quality, dryer steam. At least that's my theory since I had some water spitting out of the vents soon after I insulated the pipes. By insulating the copper, did I just increase the probability that I'll have a leak? The date of manufacture on the boiler is September, 1998. I'm assuming there's been no leaks since it was installed.
Before and after pics attached.
Thanks,
mk
  • Abracadabra
    Velocity of the steam out of the boiler may still be creating wet steam.
    Jamie Hall Member Posts: 27,349
    But the insulation won't increase the probability of a leak.
    kcopp
  • gerry gill
    gerry gill Member Posts: 3,084
    While the piping isn't optimal, there is something else at play here. Not the insulation.
    gwgillplumbingandheating.com
