Really
happydave
Member Posts: 79
Walked into this today
+1 get'r dun.0
I've really got nothing personal against Neanderthals, but HappyDave, it looks like you've been following them around, getting to enjoy their work! Life might be easier if you start following Cro Magnons instead.
That switch, hooked up to the boiler, water heater and pump controls what???
Yours, Larry0 -
vacuum breaker...CHECK
everything else is poo0 -
Larry, that's the master switch of everything0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
