Insulated Near Boiler Piping - Copper
mpkozar
Member Posts: 13
I recently purchased a 1920 era house in the Hampden neighborhood in Baltimore. After reading the forum in depth as well as Dan Holihan's "We Got Steam Heat", I insulated all of the near boiler piping and the mains. My concern is that all of the near boiler piping is copper and now that I've insulated, I believe I'm getting a better quality, dryer steam. At least that's my theory since I had some water spitting out of the vents soon after I insulated the pipes. By insulating the copper, did I just increase the probability that I'll have a leak? The date of manufacture on the boiler is September, 1998. I'm assuming there's been no leaks since it was installed.
Before and after pics attached.
Thanks,
mk
Thanks,
mk
Velocity of the steam out of the boiler may still be creating wet steam.0
While the piping isn't optimal, there is something else at play here. Not the insulation.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
