It's almost Friday
bob eck
bob eck Member Posts: 930
This will not work! All the good stuff will bypass the boiler drain and run out the bottom of the nipple. They need to put a ball valve under the boiler drain and close it.
You know what I thought to much about this.
Oh I hope they used lead free brass fittings and valves you don't want lead poisoning!!
Timco
