It's almost Friday
bob eck
Member Posts: 930
This will not work! All the good stuff will bypass the boiler drain and run out the bottom of the nipple. They need to put a ball valve under the boiler drain and close it.
You know what I thought to much about this.
Oh I hope they used lead free brass fittings and valves you don't want lead poisoning!!
1
This is why Utah beer is only 3.2%.Just a guy running some pipes.0
???0
What?0
Go ahead and take the rest of the week off, maybe Monday will be better.0
Am I missing something? Was there a picture in the OP?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Squirrel2
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
