It's almost Friday
bob eck
Member Posts: 930
This will not work! All the good stuff will bypass the boiler drain and run out the bottom of the nipple. They need to put a ball valve under the boiler drain and close it.
You know what I thought to much about this.
Oh I hope they used lead free brass fittings and valves you don't want lead poisoning!!
1
This is why Utah beer is only 3.2%.Just a guy running some pipes.0
???0
What?0
Go ahead and take the rest of the week off, maybe Monday will be better.
Am I missing something? Was there a picture in the OP?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Squirrel2
