Oil Gauge Help
bsullivan
Member Posts: 5
Hello all, new here to posting. Feeling a little silly asking, but which part of the gauge here do I read? The top of the needle or the actual yellow float?
Thanks!!!
Thanks!!!
Need a picture. Not sure what gauge you are talking about.
Rick0 -
Very tough to tell because of the variables like weather and all that, but by keeping the house (1600 sq feet split level built in 1994, at 67 degrees will this be enough to make it until delivery on Tuesday? We never let it go this low but due to some unforeseen circumstances we had to bump the delivery out two weeks. It's chilly here today, about 20 and showing and we're looking at temps around 30 and about 2.5 feet of snow over the next two days.
Thanks so much0 -
The best i could say is... maybe. It wouldn't be enough for the place I care for, but you might be able to get by.Br. Jamie, osb
2.5 feet of snow coming, I'd get oil before it snows.
1/8 of a tank is about 30 gallons. But, if you're drawing the oil out of the top of the tank, you're just about empty.
If you're drawing out of the bottom, you risking clogging the oil line/filter.
If you absolutely have to wait until Tuesday, you can run to the local gas station with some 5 gallon cans and dump some diesel fuel into the tank. If you live in a rural area and the gas station sells Off Road Diesel, that will be cheaper and that will work too.
BTW, the gauge is as accurate (when working correctly) as the ones in your car. You will know empty when you see where it is when you run out.There was an error rendering this rich post.
Thanks a lot everyone!0
Looks to me the indicator dropped down the needle. Unscrew the vial and pull the disc to the top of the needle.
If you're handy, you can install a wireless gauge like the Beckett Rocket. I installed one when I installed a new above 275 outside. Just make sure you set the dip switches correctly on the receiver.0
- 120 Geothermal
