looking for replacement tailpieces for runtal valves
Boon
Boon Member Posts: 261
I'm looking for at least 4 extra tailpieces for Runtal decorative radiator valves. I don't see them sold separately.
The valve & tailpiece don't seem to be a pair, you know, like ground joint unions, so I'm wondering if there is a generic tailpiece that might also work. Anyone know? If there is, I'm not going to be picky about the other end of the tailpiece... sweat, threaded, female/male, ... whatever.
For what I'm doing, I don't really need these extra tailpieces to be decorative.
Thanks
David
DIY'er ... ripped out a perfectly good forced-air furnace and replaced it with hot water & radiators.
    hot_rod Member Posts: 27,344
    got a pic of the valve?
  • Boon
    Here are a few with a couple measurements. Thanks.
    Definitely seals with a washer
    wish I had a thread gauge
    Inside diameter
  • Boon
    @hot rod a Caleffi PEX manifold fitting worked! Mostly. I mean, it would not pressure test at 100psi but it held at 50psi, which is good enough for my temporary use.
