Radiator Vent Considerations
cubicacres
Member Posts: 360
As part of our water leak/energy use issues on other threads, the last radiator on the long line has been noisy or too cold for the tennants. Packing the supply valve nut may have solved the noise problem since the stem was very lose (we'll see as the weeks go by and they report back to us).
For radiator vents, is a smaller vent generally better for rooms that get too hot to slow down the new steam entering the rad, and does the rad size in the room (large or smaller) happen to matter if too hot anyway? We'd like to just reduce the vent speeds in the hotter 2nd floor rooms to suit the tennants, or increase the vent speeds in the colder 1st floor rooms. Are other considerations needed to be taken into account, or can this be done as simply as it sounds above?
It's just as simple as it sounds. And just as fiddly. You may get it right on the first try, then again you may not -- particularly as changing one radiator may affect other radiators, particularly if they are on the same riser.Br. Jamie, osb
We're thinking about swapping the hoffman 1a vari-vent with a thermostatic vent for our tennant who wants the bedroom rad off completley during the night. Any suggestions on which TRVs, or how they're different? I suppose some have larger vents, or different technology?
For some reason turning the hoffman vent upside down worked to keep the rad off in the dining room but didn't stop the rad in the bedroom.0 -
Turning the vent upside down, and still having a hot radiator indicates high pressure to me. How many ounces are you seeing on your gauge both during steaming, and backpressure of the venting phase?--NBC0
Our pressuretroll gauge has a 0-30psi range and never seems to move off of 0 psi. I think the cut-in is at .5 or 1 psi with a differential of 1, so a cut-out of 1.5 or 2 psi last time we checked.
Can we simply buy a 0-3 psi gauge, attatch it with a pigtail & some short pipe segments and watch how we're doing? If we have higher pressure and it goes above 3 psi, does it risk breaking the 0-3 psi gauge? How does higher pressure occur in a lower pressure system like ours?0 -
I would say it means the vent is leaking.nicholas bonham-carter said:Turning the vent upside down, and still having a hot radiator indicates high pressure to me.
Consulting0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 385 Solar
