Customer asked for a steam vacuum breaker?
bob eck
Member Posts: 930
Customer is looking for a 1/4" steam vacuum breaker for a steam boiler.
Who makes this item?
Thanks
Thanks
You can just use a swing check valve or Tunstall Associates on this site has steam rated vacuum breakers. Won't be 1/4" though probably 1/2 or 3/40
I make a 1/4" vacuum breaker, machined out of solid bar stock right here in the USA.
Like this but 1/4" npt
http://www.amazon.com/Barnes-Jones-MPT-Vacuum-Breaker/dp/B0191X6YK6
Peter Owens
SteamIQ0 -
Has this system got Hoffman 76 main vents?
If so, the disk-check valve can be unscrewed and removed.--NBC0 -
There you go @Sailah has just what you need0
