Customer asked for a steam vacuum breaker?
bob eck
Member Posts: 930
Customer is looking for a 1/4" steam vacuum breaker for a steam boiler.
Who makes this item?
You can just use a swing check valve or Tunstall Associates on this site has steam rated vacuum breakers. Won't be 1/4" though probably 1/2 or 3/40
I make a 1/4" vacuum breaker, machined out of solid bar stock right here in the USA.
Like this but 1/4" npt
http://www.amazon.com/Barnes-Jones-MPT-Vacuum-Breaker/dp/B0191X6YK6
Peter Owens
SteamIQ0 -
Has this system got Hoffman 76 main vents?
If so, the disk-check valve can be unscrewed and removed.--NBC0 -
There you go @Sailah has just what you need0
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 734 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
