Viessmann Vitodens 200 6-24C code 06
zac_2
Member Posts: 32
Need help as Viessmann tech support is now closed for the weekend and I have cold irritated customers.
During a cold spell about 2 weeks ago now boiler shut down with a code 06 and red fault light but would randomly also display a 07 and FE when reset. I checked all the venting for possible ice build-up or other blockage but it was clear. After talking with tech support they thought the LGM board was burned out due to the randomness of the errors so I replaced that and it now consistently displays code 06 and no red fault light. After second call to tech they suggested I verify blower function by pulling the high limit wire, I did that and no blower which felt quite hot to the touch. I just replaced the blower this afternoon but still code 06. I am able to clear the error and it stays clear but no start-up sequence. Now when I pull the high limit wire blower does start so I'm pretty confident both board & blower were toast but what would you recommend the next step be?
Is venting the right size and distance?0
