Top floor radiators hot...2nd floor radiator cold.
LI_CJ
LI_CJ Member Posts: 11
I just had my boiler replaced with a nice Peerless unit. I have a few radiators where are notoriously tough to bleed, and I think a little bit of air re-entered the system during the boiler replacement.
I successfully bled my third floor rads, but I have one on the 2nd floor in the bathroom that is cold. I have water coming out of the bleeder (vs air), so I'm thinking there is an air pocket trapped. The feed pipe to the radiator is warm.
Should I just run water out of the bleeder until I find the remaining air? I haven't attempted to bleed more than a quart or so at one time...so maybe I need to be more aggressive and run a few gallons through.
Any other suggestions?
    hot_rod Member Posts: 26,587
    Or you may need to do a good high pressure purge again.
    If there is an airlock or bubble in the piping, it may be hard to bleed that out at a radiator.
    Usually there is a means to isolate and purge the various zones or loops in the boiler room. Shut off valves and purge cocks of some sort.
    Does the system have a good quality air purger back at the boiler? that will take care of any air that circulates after the initial purge id performed.
  • LI_CJ
    I'm good now. Revisited and the air worked its way through. One more purge and now I'm hot!
    Thanks.
