can someone tell me how to connect the two red wires to the switching relay
pooteo
Member Posts: 19
in Oil Heating
a single zone taco switching relay with 4 wire uponor actuators. using the 2 wire thermostats as end switches.
i can't figure out how to connect this setup to the relay for the circulator pump.
Any help would be greatly appreciated. I've already burnt out one transformer hooking it up wrong.
if the control has a step down transformer why are you adding one ??
I'm hooking up multiple zone actuators and using the transformer to power them all.0
Same conversion on this thread http://forum.heatinghelp.com/discussion/160886/help-with-4-wire-uponor-actuator#latest
Better to just post it once."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I posted to the wrong thread and can't figure out how to delete this one.
Zman answered my question. Thank you.0
- 120 Geothermal
