V155 sticking
Member Posts: 3
in Gas Heating
A converted coal to gas gravity heat furnace with a Honeywell V155 gas valve that sticks open. The slightest vibration releases it.
Same answer as on the Wall:
You need to get some Honeywell "FINOL" and insert a few drops into the small cups supplied on the valve. This will lubricate the valve and it should resume normal operation.
The V155 valve is an old Series 10 gas valve and it is motorized0
- 123 Chimneys & Flues
