Full-slip adapter
Does anyone know of another name or another product number for this? It'd work great for a special order bath spout I just got asked to put it. This few bucks would all me to solder without opening out the walls in the ensuite to adapter to the existing copper stub out.
http://www.supplyhouse.com/Sioux-Chief-614-2-1-2-Female-Sweat-x-1-2-MIP-Full-Slip-Brass-Male-Adapter
I'm in Canada and cannot order from them.0
Urinal adapters is what I've called them.Bob "hot rod" Rohr
Sorry this one is 1/2x1/2. I have seen urinal and closet ones that are 1"x1" and 1"x3/4". They come with Delta Flushometers because they have the valve body for urinals and water closets.0
Oh right I guess we have manual urinal valves that can be 1/2" in size and pass code. Just don't see those too often. Sorry if I implied you'd missed the sizing hot rod. I should have known better.0
www.supply house.com or Home Depot Supply lists the same Sioux Chief adapter if that helps0
Still cannot get Sioux locally. Wolseley is a dealer but they don't even list it in there catalog. I need if by Friday if I am going to use it. Otherwise I'll cut the wall on the opposite side and put in a wingback 90 and brass nipple and patch it back up.0
No problem. Urinal adapter as a generic term. They come in 1/2, 3/4 & 1"Hilly said:Oh right I guess we have manual urinal valves that can be 1/2" in size and pass code. Just don't see those too often. Sorry if I implied you'd missed the sizing hot rod. I should have known better.
Sioux Chief, Supplyhouse.com, Home Depot, probably Amazon.
Homedepot lists nothing on .CA but I know they just switched to Sioux Chief for all there 1/4" up to 3/4" random push fit, brass threaded, flares, compressions, plastic... So I'm hoping if I go there tomorrow I might just luck out.
I guess my point of the thread was to see if there was different terminology to use when attempting to call the local suppliers tomorrow.0 -
text them a pic of what you are looking for. Brass MIP slip adapter.
Does Amazon deliver up there, probably get them next day
And what are you doing up in Canada anyways?
@Hilly that adapter is a flushometer valve adapter. Sloan, American standard, Toto and Zurn those are the companies that I can think of off the top of my head make flushometers so I would check which of your wholesalers has anyone of those manufacturers flushometers in stock0
Yeah I saw that link hotrod... About 45x the cost. Ha ha ha0
That's also available from Nibco, 704-F for the part number.0
- 15.8K Strictly Steam
