About to replace a 800k smith. Want to fix a major issue.
Timco
Member Posts: 3,040
I'll get pics up. They are on my phone.
This boiler floods bad when the power is off for an extended time or it starts from cold. Then of course it hammers really hard.
Will simply adding more return volume solve this? There's no real return now. The dry returns dump right into one 2" that ties right in. No real wet return.
Just a guy running some pipes.
One-pipe or two-pipe?
Did you check to see if the water feeder is leaking?All Steamed Up, Inc.
Consulting0 -
Two pipe. It keeps a great water level during operation but there's no meter on it. Since I haven't seen it right after an outage (only next morning) it could very well be. It's flooded up into the mains. It all goes anyway. See pics in the main wall.
Just a guy running some pipes.0 -
my guess is water feeder is leaking or manual fill valve is leaking.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
